11/5/2011 11:01 AM | |
Posts: 11 Rating: (0) |
Hi all, I am using Redundant DI16 MTA (6ES7650-1AC11-3XX0) module which will be connected to 16DI Modules (6ES7321-7BH01-0AB0). All even channels (CH0, CH2, CH4...CH14) are grouped together and similarly all odd ones are grouped together. (Please see attached pdf) I need your help to assign address to these inputs. Should i match channel no. with address (i.e. I x.0 for CH0, I x.2 for CH2, I x.10 for CH10 etc) or should i assign address in the order which channels appear ( i.e. I x.0 for CH0, I x.1 for CH2, I x.2 for CH4 and so on). I think first method is correct since signal arriving at CH0, CH2 etc. will be available at 0th input, 2nd input of DI module respectively. Please advice. Attachment16 DI MTA Module.pdf (328 Downloads) |
