6/20/2024 12:04 PM | |
Joined: 8/3/2009 Last visit: 6/27/2024 Posts: 13163 Rating:
Hello Ziemens 'some Versions of WinCC flexible and TIA Portal are released with each other Check in the Compatibility lists: https://support.industry.siemens.com/cs/de/en/view/64847781 Bye Murof |
