10/26/2010 2:35 PM | |
Posts: 1530 Rating: (59)
Dear ry_fern, I assume that you tried to add an user text block with the name "description", didn't you? If you open alarm logging, select "User text block" and select "Add/Remove" you see all the available text blockson the left side, and alle the selected text blocks on the right side. You also will see some text blocks with the name Free1 to Free 5. You may change the names of this free blocks, for example into "description". For information concerning the treatment of message blocks please take a look at the following link. https://www.automation.siemens.com/mdm/default.aspx?LibGuid=f2146bfd9b9547399884ba0ac3735be3 Best regards Bizur |
10/27/2010 1:19 PM | |
Posts: 32 Rating: (0) |
Bizur, Problem solved. Thank you very much. |
