5/7/2015 11:18 AM | |
Joined: 1/28/2009 Last visit: 5/20/2024 Posts: 6840 Rating: (1359)
Hello, I don't think it is possible in Engineering Phase in STEP 7, For that , you should generate your alarms and tags you want.In SIMATIC WinCC, you can add extra information to text in your further development in WinCC( but added data will be lost in the next OS compilation).More references can be found: How do you implement chronological messaging with S7-300 CPUs and WinCC?
I hope this helps, hdhosseini |
5/12/2015 3:56 PM | |
Joined: 9/27/2007 Last visit: 12/18/2020 Posts: 993 Rating: (102)
Hello Karsten, while searching for a solution regarding another problem with messaging, I found a solution regarding your request: to get a tag in your message text please open Alarm logging editor, create a new alarm, go to "Message text" click into the field, press right mouse button, open context menu, select Edit. And then you are able to select process value and concat message text. Please see online-help and search for "How to specify Message Text for a Message" Georg |
Learn more about visualization - visit the HMI courses of Siemens AG! |
