1/21/2022 7:08 AM | |
Posts: 2 Rating: (0) |
Hello. I have exactly the same problem. 230021 Axis Z SERVO_3.3:5..... Power Supply: Earth fault- 32767. 230005 Axis Z SERVO_3.3:5..... Power supply: Overload I2t 16384. Drive 1P-6SL3120-1TE21-8AS0 Diagnosed 1) by disconnecting the power cables from the unit (the error is the same) 2) by replacing the X-axis power cables (the block is the same), the error is the same. I changed the blocks themselves to X, the error went with the block to X. I think something is wrong with the block. Maybe my information will help someone. Later I will write what we came to. ------------------------------------------------------------------------------------------ |
Last edited by: Max2303 at: 01/21/2022 07:09:50Last edited by: Jen_Moderator at: 01/21/2022 11:37:14New subject after splitting |
