11/11/2020 2:36 PM | |
Joined: 1/17/2020 Last visit: 5/11/2024 Posts: 46 Rating: (6) |
Hi , "Non-wired output channels: To ensure that non-wired output channels of the analog output module SM 332; AO 8 x 0/4...20mA HART are deenergized, you have to deactivate them. You deactivate an output channel using STEP 7 by means of the "Output" parameter block. Wiring with resistors is not necessary." Hope is useful for you! Rate please :) |
Rate please if it was useful! |
