4/8/2018 4:33 PM | |
Posts: 200 Rating:
Hi I am quite new to the 1200 and have attached a sample of my software. for my learning i have created a little program where i have a 0-10v input into my 1212c base unit which represents my level sensor of a tank. My tank has 8tf of water. I have then added a high alarm, low alarm and a fill valve. Please could you look and see that i am scaling correctly Thanks in advance AttachmentTowns Water 1200.zip (65 Downloads) |
4/9/2018 9:04 PM | |
Posts: 200 Rating:
hi thanks for the reply and the pointers shown i have tried the software all seems fine i have attached a screen shot of the software and have a question on the numbers shown which i take are the scaled measures in FT i will check the sensor data sheet and check the setting for the 0-10v AttachmentDoc1.pdf (70 Downloads) |
4/9/2018 9:30 PM | |
Posts: 200 Rating:
i have highlighted on page 2 what i think are settings for the output
AttachmentFile-1453295921.pdf (60 Downloads) |
