5/3/2020 3:21 PM | |
Joined: 9/27/2006 Last visit: 8/14/2024 Posts: 12277 Rating:
Hello uel123; I must admit I have never come across suc a situation. So asll I have to offer are more FAQs, maybe there is an answer in one of these: How do you enable cross-project S7 Routing in the TIA Portal and in STEP 7 V5.x? "The instructions below show how to make an S7 station configured in STEP 7 V5.x routing-compatible for an S7 station configured in the TIA Portal." https://support.industry.siemens.com/cs/ww/en/view/109474569 How do you configure and enable S7 Routing in STEP 7 (TIA Portal)? https://support.industry.siemens.com/cs/ww/en/view/109736340 Hope this helps, Daniel Chartier |
5/5/2020 5:52 AM | |
Joined: 5/12/2006 Last visit: 8/14/2024 Posts: 22343 Rating:
hello, yo can check this FAQ if the info you search is here Which modules support the "S7 Routing" function in S7 subnets? Regards |
5/5/2020 7:51 AM | |
Joined: 1/29/2006 Last visit: 8/9/2024 Posts: 446 Rating:
Hi! I have allready checked. All my HW is listed there.... Thanks! uel123. |
