11/7/2019 7:23 AM | |
Joined: 3/5/2017 Last visit: 5/9/2024 Posts: 769 Rating: (126) |
Hi, That should be right (except dst ByteAddressLSB is #pAnySRC.ByteAddressLSB). Assuming that you have build your ANY Pointer correct. If it does not work, attached is pictures of another working way to do it. I use Load memory DB's, that's why READ_DBL.
AttachmentAnypointer.zip (372 Downloads) |
Last edited by: K_Ohjus at: 11/07/2019 07:32:37- Trying is the first step towards failure. |
11/7/2019 7:53 AM | |
Joined: 10/18/2006 Last visit: 5/8/2024 Posts: 120 Rating: (15) |
Hi, this looks fine. What return value do you get from your BLKMOV call? |
iba AG - Data Acquisition and Analysis the way it should be |
11/8/2019 11:35 AM | |
Joined: 4/4/2018 Last visit: 5/6/2024 Posts: 82 Rating: (1) |
The return value is Zero. |
