9/24/2015 3:42 PM | |
Joined: 1/28/2009 Last visit: 9/2/2024 Posts: 6846 Rating: (1365)
Hello ,
The sample code you shared is using dynamic ANY formation for iterative mass data transfer from source area (ptANY ) that is calculated in each iteration to the target area.Search for ANY pointer in STEP 7 Online manual for structure of it and the meaning of each section plus data type. The other point worth mentioning would be using AT function to break 10 bytes ANY structure to smaller manageable partitions. How can you construct an ANY pointer in S7-SCL using the AT function?I hope this helps, hdhosseini |
