5/26/2017 11:26 AM | |
Joined: 12/9/2010 Last visit: 10/8/2022 Posts: 623 Rating: (76) |
Hi rtuncer, This error is due to either DB is not loaded or DB is of shorter length. So initially download all DBs. Select statio n and press control D. Now go to dia. buffer tab. Select the diagnostic entry and press Open block. It will open the block which is responsible for causing error. |
If you like the comment, rate it (right top) or thank it (left bottom). |
5/30/2017 11:12 AM | |
Joined: 9/16/2013 Last visit: 1/5/2024 Posts: 511 Rating: (106) |
JUst before this switch to online and delete OB121 |
Website: |
