7/27/2023 2:38 PM | |
Joined: 2/17/2020 Last visit: 6/3/2024 Posts: 1008 Rating: (177) |
Hi, Please see the following section of the manual for clarification: WinCC/Audit V7.5 SP2 - Licensing In a multi-user system, you will need a WinCC Audit RT license for each PC on which only Audit Runtime is running (installation of individual Audit components). This will allow you to save changes in WinCC Runtime and WinCC Configuration to a database. You will also need a WinCC Audit RC for the engineering. That is, configurate tracking of changes in WinCC Runtime and WinCC Configuration. Hope that helps! |
A rating will be well appreciated. |
