8/11/2024 9:05 AM | |
Joined: 4/16/2019 Last visit: 8/11/2024 Posts: 32 Rating: (0) |
Thanks for responding I have already searched in forum but I have not found a lid |
8/11/2024 6:21 PM | |
Joined: 9/21/2012 Last visit: 8/12/2024 Posts: 4090 Rating: (459) |
Here's a couple of search results for you to go through. Search words: end call The other search words are from an error you get from that block Search words: there is a stamp conflict with at least one block call The problem you are facing is because the block was originally done in SCL and when you upload it, you can only see it in STL. All SCL is compiled to STL before uploading to the PLC. |
