3/26/2019 10:20 AM | |
Joined: 7/9/2015 Last visit: 9/26/2024 Posts: 3946 Rating: (587)
Hi, I would project an array of char. First Element you can compare if its char "y". With other char you can do a loop to get acces to the elements of the array and compare it. 0-9 as character is value hex 30 - to 39 - so every charakter must be between hex 30 and hex 39. How do you obtain indexed access to an array in S7-SCL?Regards, Towome |
