6/26/2014 5:06 PM | |
Joined: 9/27/2006 Last visit: 6/7/2024 Posts: 12260 Rating: (2670) |
Hello shiwam; Any certfied Profibus-DP slave can be integrated in a Profibus-DP master configuration, it does not matter what manufacturer had it developped and certified. The tool to integrate a Beckhoff slave (for example) in any Profibus-DP masterconfiguration is the gsd file (the last letter of the extension file name is language dependant, gsd is for default, gsg is written inGerman, gse is English...). You can find the Beckhoff gse files and information in these links: http://download.beckhoff.com/download/Document/BusTermi/BCoupler/BK3xx0en.pdf http://www.beckhoff.com/english.asp?bus_terminal/bk3150.htm And follow the suggestions in this forum discussion to see how to insert the Beckhoff gse file in your Step 7 Profibus configurator. Hope this helps, Daniel Chartier |
