4/6/2024 10:34 AM | |
Joined: 3/3/2015 Last visit: 7/5/2024 Posts: 2 Rating:
I am constantly frustrated by the too often arrangements of panes in the TIA portal that only leaves me with 3 cm. of editing space. I'm tired of closing down panes and moving lines to get a usable editing space All monitor-upgrades results in wider monitors, but that does not really resolve the issue of the narrow editing space. Have anyone considered to use, or are using the "DualUp" (16:18) monitor? https://www.lg.com/us/monitors/lg-28mq780-b-dualup-monitor It seems that this type can give a good editing area and also have the Properties-pane up. Any thoughts? Best regards |
4/8/2024 1:12 PM | |
Joined: 7/7/2010 Last visit: 8/15/2024 Posts: 15090 Rating:
Better way to work with existing monitor in TIA Portal (topic title shift): Once you like the window layout, click the "Save Window" setting button in the upper right of the working pane. If you are very particular about this right away, over time you find your working pane is maximized most of the time you want it maximized, and one click away most of the rest of the time.
science guy |
