4/5/2018 11:23 AM | |
Posts: 13 Rating:
it's windows 10 professionnel. STEP 7 v5.6+HF1 K5.6.0.1 |
4/5/2018 12:03 PM | |
Joined: 9/3/2008 Last visit: 7/17/2024 Posts: 926 Rating:
Hi ohamenniche Try to make a new directory on your C: og D: drive like "C:\Projects". I see that you Step7 is French?; but in English, select "Options -> Customize" and for the default project directory, select the directory "C:\Projects". Then close Simatic Manager and open it again. See if this helps. Try to put your projects in this directory. |
Michael |
4/7/2018 10:12 AM | |
Posts: 13 Rating:
unfortunetly. when i restarted the computer , i had the same problem |
4/14/2018 9:38 AM | |
If the issue is related to .NET Framework, you might want to try the Microsoft .NET Framework repair tool to see if it helps. |
Michael |
