11/15/2018 4:40 PM | |
Joined: 11/4/2018 Last visit: 5/14/2024 Posts: 62 Rating: (0) |
Murof - it worked perfectly! Thank you! If I have a project containing PLC and HMI, but I'm working on HMI part and another engineer is working on the PLC part, when we want to merge the projects what's the best way to do that? What I did try is to open 2 instances of TIA Portal and then copy from one project to another but this breaks my faceplate tags (they turn red) even though in my HMI tags I can see "HMI_Connection". But the weird thing is that when I click next to the broken tag and then navigate and select the same tag again in the PLC, it then connects and links again... Do you know what the best solution is for that problem? Thanks
Last edited by: Jen_Moderator at: 11/16/2018 7:21:18 AMNew subject after splitting |
