11/17/2022 4:18 PM | |
Joined: 7/27/2022 Last visit: 5/31/2023 Posts: 1 Rating: (0) |
hello, did you manage to find a solution to your problem? i have a similar problem. i am using a Simatic ET200 to monitor the level of a dam, now there's a bus fault on the et200 and i keep on losing the level. i changed the power supply, i changed the bus connectors but the fault won't go away. on the diagnostics buffer it shows (I/O access error, reading. please assist ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 11/18/2022 08:01:08New subject after splitting |
11/18/2022 4:17 PM | |
Joined: 8/6/2018 Last visit: 11/11/2024 Posts: 297 Rating: (40) |
hello, could you send us the cpu diagnostic buffer? Thanks you |
