1/19/2015 3:38 AM | |
Posts: 8 Rating:
Deareisenpferdreiter, I aslo replace the Profibus cable and connector, but it's still problem, any idea from you?Thanks & Regard |
1/19/2015 4:15 AM | |
Posts: 56 Rating:
(1) Please check the cable routing for any interference with power cable. (2) What is the distance between the nodes? |
1/19/2015 4:50 AM | |
Posts: 56 Rating:
Try the following (1) Check the back pin connectors for any bend or loose connections .. (2) Try to changing the IM module
