8/11/2016 4:17 PM | |
Joined: 9/27/2006 Last visit: 10/13/2024 Posts: 12287 Rating: (2685) |
Hello Duccio; I wish I could answer yoiu as well as our friend smiffy (but I am vey glad he has provided the information and context for a better answer), in this discussion: C++ to SCL programming https://support.industry.siemens.com/tf/ww/en/posts/36944/ Hope this helps, Daniel Chartier |
8/11/2016 4:57 PM | |
Joined: 12/7/2011 Last visit: 8/16/2024 Posts: 384 Rating: (9) |
Hi dchartier, thanks for your reply, i'll read soon as possible that post. Regards. Duccio. |
8/12/2016 10:58 AM | |
Joined: 4/28/2015 Last visit: 2/7/2024 Posts: 10533 Rating: (820) |
Hello, give yourself simple question about possibility of compiler from Pascal (SCL has some signs but not full option, it's prepared to Automation needs) to C or vice-versa, probably big problem. It simply begin from C language, it has so much options that I can't imagine on Automation systems, but this is also to discussion. What exactly you want translate/convert? Daniel's link to Smiffy's answers is right info to understand that... Update: also if I can show something, look to this topic, I think it show something that is very close to f.ex. C pointer meaning: S7 200 XMT Usage in Freeport Communication Maybe other common system but not in Automation is .NET but this is other system... |
Last edited by: Duris_I at: 8/12/2016 11:00:15 AMLast edited by: Duris_I at: 8/12/2016 11:03:37 AMLast edited by: Duris_I at: 8/12/2016 11:39:33 AMWith best regards... |
8/12/2016 3:39 PM | |
Good to know, but unfortunatelly i never heard B&R PLC , and i need to work on SCL. Duccio. |
8/12/2016 3:52 PM | |
Hello; For certain new projects we are starting to work wth Beckhoff platforms. Their programming software (TwinCat 3) is Codesys-based. Certain clients require that we work with C++ functions developped for special applications and extend them. to solve their applications Beckhoff allows this on their TwinCat 3 XA platform: https://www.beckhoff.com/english.asp?twincat/twincat-3-xa-language-support-c.htm?id=1893323818933256 Daniel Chartier |
Last edited by: dchartier at: 8/12/2016 3:53:48 PMLast edited by: dchartier at: 8/12/2016 3:55:18 PM |
