1/25/2024 1:55 PM | |
Joined: 8/3/2009 Last visit: 9/11/2024 Posts: 13647 Rating:
Hello Any errors that occur are displayed with the SF LED and the cause of the error is So in diagnostic buffer you should see what is the reason of the errors. Here is a manual if you need: https://support.industry.siemens.com/cs/de/en/view/1136211 Bye Murof |
