12/8/2010 3:00 AM | |
Joined: 9/27/2006 Last visit: 6/6/2024 Posts: 12260 Rating: (2670) |
Hello jimmyto; If you open this link, you will find a table that shows the compatibility of Windows OS and MicroWin. http://support.automation.siemens.com/WW/view/en/8675614 You will see that there is no version of Microwin that is compatible at present with Windows 7. So your installation cannot communicate properly with the PLCs. You should look into using the VM XP shellon your machine, as provided by Microsoft http://www.microsoft.com/windows/virtual-pc/download.aspx Also make sure that the version of OS you use isWindows 7 Profrssional (or Business) 32-bit. Hope this helps, Daniel Chartier |
