3/7/2018 10:43 AM | |
Joined: 4/28/2015 Last visit: 10/9/2023 Posts: 394 Rating: (55)
Hello, maybe you will find some information about using a cam disc in chapter 4.4 of this document: https://support.industry.siemens.com/cs/ww/en/view/109743136 Not to reach the maximum speed of an axis, you should try to configure the motion control function to move leading axis double of the way the following axis does to the synchronous position... In this case, there is no need for following axis to "overspeed"... Maybe this will help you. |
