5/7/2024 9:57 AM | |
Joined: 4/18/2022 Last visit: 5/15/2024 Posts: 1 Rating:
Hello I have a one questıons, Can I install Tia Portal v18 and wincc 7.4 Sp1 together in windows 11 ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 05/07/2024 11:42:31New subject after splitting |
5/7/2024 5:50 PM | |
Joined: 2/17/2020 Last visit: 6/14/2024 Posts: 1010 Rating:
Hi, It depends. If you intend to install WinCC Professional on TIA V18, then it would not be possile due to the SQL conflict. I would recommend using the WinCC V7.4 compatibility list to confirm before installing. |
A rating will be well appreciated. |
5/7/2024 5:51 PM | |
My mistake. You need at least WinCC V7.5 SP2 Update 7 to install on Windows 11! |
