10/13/2016 8:04 PM | |
Posts: 2 Rating: (0) |
Hi guys, good day / Night. Somebody can help me please ?? I removed the firmware of my CPU 1214C DC/DC/DC E.g. (6ES7 214-1AE30-0XB0) with Reset Factory command and now I am finding a big problem to update my PLC. So I'd like to know if I can use the Memory Card 12M E.g.(6ES7954-8LE01-0AA0) to update my CPU? I need to know it before of purchase because the MEMORY CARD is very expensive in Brazil.
Another question, I can update my PLC by web server using Tia portal software? What's the procedure? what´s step by step ? Thanks all!! ------------------------------------------------------------------------------------------ |
Last edited by: Min_Moderator at: 10/14/2016 9:15:51 AMNew subject after splitting |
10/13/2016 9:21 PM | |
Posts: 5225 Rating: (1196)
Hi. Those cards are expensive... not only in Brazil. That card is also the only official way to change the firmware in your version of the PLC. Did you see the text in the previous posts - you already have steps to follow. But it is best if you get hold of the S7-1200 System Manual and find the information there. How did you determine that the firmware was wiped? As far I know the firmware should remain intact. See the attached for detail. (Extract from the System Manual.) w AttachmentEXTRACT_Reset to factory settings.pdf (279 Downloads) |
