2/27/2007 11:52 AM | |
Joined: 4/24/2006 Last visit: 7/12/2024 Posts: 8711 Rating:
Hi, Have you seen this link: http://support.automation.siemens.com/WW/view/en/24786764 Perhaps it can help you. And perhaps you can use Analog multiplexer with AQ. Best regards, Wizard |
3/25/2007 9:32 PM | |
Joined: 1/5/2007 Last visit: 4/7/2023 Posts: 1690 Rating:
Hi Gazz, i think your question is not unequivocal asked, but.... Should you have, different than "Wizard" picked up, an analog input and you want to divide this into different ranges/areas, then helps maybe my example. Best regards, Betel AttachmentAuswertung_Analogeingang_V01.zip (709 Downloads) |
==> Meine TAG-Listen: "deut." |
3/27/2007 10:36 AM | |
Posts: 9 Rating:
Thanks Betel my question was 4 analog inputs high selecting the highest one and using this highest one to modulate a 0-10v valve motor |
3/27/2007 11:52 AM | |
Posts: 661 Rating:
Hi gazz, i´ve attached a little example program. I think this could be the beginning of yourapplication ... Best regards Fux AttachmentHi-select.zip (802 Downloads) |
3/27/2007 12:36 PM | |
Posts: 9 Rating:
Thanks Fux that was very well engineered and I thank you for taking the time. Worked great. Thanks Gazz. This works new attachment. Attachment4CH HI-SELECT 0-10V.zip (755 Downloads) |
Last edited by: gazz at: 09.04.2007 07:58Last edited by: gazz at: 09.04.2007 07:53 |
