5/22/2024 7:48 AM | |
Joined: 5/17/2022 Last visit: 6/10/2024 Posts: 1 Rating:
Hello every one. I'm using TIA Portal V18. My problem is I can't Accessible to devices. But if I know the PLC's IP address, I can start search and select show devices with the same address. I can find the PLC. But if I select show all compatible devices or show all accessible devices I don't find the PLC. And PRONETA program in the select network adapter section I also don't find the Ethernet card. Everyone please suggest me a solution. thank you. AttachmentScreenshots.zip (127 Downloads) |
Last edited by: Jen_Moderator at: 05/22/2024 10:04:23Text formatting optimized. Last edited by: Jen_Moderator at: 05/22/2024 10:06:07All files added as .zip file. |
