10/30/2018 1:14 PM | |
Joined: 11/15/2015 Last visit: 5/18/2024 Posts: 179 Rating: (28) |
Hello, To configure it as Safety I/O you will need the optional package S7-Distributed Safety.https://w3.siemens.com/mcms/simatic-controller-software/en/programming-options/distributed-safety-sw/pages/default.aspx Regards, ========================================================= Look for alternative not for the correct answer.... |
Look for alternative not for the correct answer...if this is helping you rate it. |
10/30/2018 1:31 PM | |
Joined: 6/28/2017 Last visit: 12/20/2022 Posts: 661 Rating: (39) |
You didn't understand my question, I think. The Safety Distributed V5.4 SP5 itself was installed long ago. I just need some info about what I need to update to get in HW catalog these relatively new F-modules, e.g. 6ES7138-4FA05-0AB0. Msorich Update: I installed this latest HSP. latest HSP 09/2018 There' no needed modules there! |
Last edited by: Msorich at: 10/30/2018 2:04:27 PMLast edited by: Msorich at: 10/30/2018 2:05:14 PMLast edited by: Jen_Moderator at: 10/31/2018 8:40:26 AMOptimized link. |
10/30/2018 6:23 PM | |
Joined: 9/21/2012 Last visit: 5/22/2024 Posts: 3946 Rating: (446) |
Have you downloaded S7 F ConfigurationPack V5.5 SP13? When you install this, you should have all available modules in HW configuration. |
10/30/2018 6:42 PM | |
Yeah... An hour ago I downloaded that pack. However, I will able to check if it is so (needed modules there are), - tomorrow. Msorich |
11/7/2018 2:48 PM | |
Joined: 10/22/2018 Last visit: 6/6/2023 Posts: 9 Rating: (0) |
Can you find a GSD file and install it into the STEP7 HW Config. |
