7/30/2014 3:53 PM | |
Posts: 1058 Rating:
Hello Scourge, there is a difference between FCS and S7-Graph - actually its two different tools. You can use S7-Graph with any S7-300/S7-400 system, as it basically creates an STL code. More info here: S7-GRAPH V5.3 for S7-300/400 Programming Sequential Control Systems Getting Started S7-GRAPH V5.3 for S7-300/400 Programming Sequential Control Systems FCS has been designed for PCS 7 and will run on S7-414H or S7-417H. More info here: SIMATIC Process Control System PCS 7 SFC for SIMATIC S7 regards |
