1/13/2009 6:42 AM | |
Joined: 9/27/2006 Last visit: 5/7/2024 Posts: 12257 Rating: (2666) |
Hello Sreeram; You probably can not connect a S7-200 PLC directly to CAN-bus, the protocols and electrical specifications are too different. And S7-200 PLCs have no CAN-bus modules in their offerings. So you should look for a gateway. The following link will show you a serial-to-CAN gateway that states it supports S7-200 PPI communications on its serial port, this could make programming issues easier: http://www.renuelectronics.com/pdfs/letter/gwy-300.pdf There are probably more offerings on the web, you will have to search there. Hope this helps, Daniel Chartier |
