6/20/2024 1:32 PM | |
Joined: 12/26/2012 Last visit: 6/25/2024 Posts: 4 Rating:
In the LAN network of the PLC I can access the Siemens PLCs and HMIs via the CP1543-1, I believe because they support S7Routing. While I cannot connect to an Industrial PC with Wincc Runtime Advanced V17 installed. I am considering using IP Forwarding following the instructions in the following slide. In your opinion, is the CP's IP address 10.10.0.1 correct in the slide...? ------------------------------------------------------------------------------------------ AttachmentIP Forwarding CP1543-1.pdf (22 Downloads) |
Last edited by: Jen_Moderator at: 06/21/2024 09:02:39New subject after splitting |
6/21/2024 9:06 AM | |
Joined: 6/19/2017 Last visit: 6/28/2024 Posts: 8176 Rating:
Hello NewCode, thank you for sharing the solution! For the next time, please try to discuss in English language. This is the translation of your post:
Regards |
