9/27/2021 4:43 PM | |
Posts: 3 Rating:
My PC couldnt find the s7-200 smart. I used the RJ45 ethernet cable. I wonder if a special cable is required instead? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 09/28/2021 08:59:45New subject after splitting |
9/28/2021 11:16 AM | |
Joined: 7/9/2015 Last visit: 7/12/2024 Posts: 3872 Rating:
Hi, check chapter 7 for communication settings. S7-200 System ManualRegards, Towome |
10/2/2021 11:23 AM | |
Joined: 4/28/2015 Last visit: 2/7/2024 Posts: 10533 Rating:
Hello,
as next recommendation is test your CPUconnected to your network with some PC SW which scan network for existing IPs. Then you can also better set your PC to be inside correct subnet as PLC is set. Only simple idea... |
With best regards... |
