10/18/2017 3:14 PM | |
Joined: 3/14/2008 Last visit: 6/4/2024 Posts: 2070 Rating: (928)
Looks familiar... When creating a recipe, first insert an Recipe Procedural Element, select a unit and then again insert a Recipe Procedural Element rather than inserting a Recipe Phase/Recipe Operation. The NOP will change to ROP and when double clicking, you can select add again a RPE or Recipe Phase/Recipe Operation (does not matter which you choos). Now you can select your EPH. |
