7/4/2014 12:04 PM | |
Posts: 94 Rating: (0) |
hi, i did ur steps and make new stat with same addreas and drag to the top but when i save the program it give me this message |
7/5/2014 10:46 AM | |
thx,great explanation but the program can make this change automatically or i have to open all FB`s and change them ? |
7/5/2014 3:20 PM | |
Posts: 5225 Rating: (1192) |
You will need to run a compile function. Compiling via the consistency check, see [LINK]. w |
7/7/2014 3:01 PM | |
hi eisenpferdreiter, the fb100 was already updated but OB1 edit > update is invisible the problem with delete old call and insert it again that i dont know what call for ? when i make update at consistency check from view > update i got no updates at anything when i make block compare i found that not only ob1 changed but also alots of DB look i will upload the archive program to u its have no errors with compile but when i make changes i get the errors in OB1 & DB alot of things changes AttachmentMetro_old_CPU.zip (141 Downloads) |
