11/8/2022 5:34 PM | |
Joined: 6/11/2019 Last visit: 7/13/2024 Posts: 2205 Rating:
but when the lift is running, I can't show it .... For the lift ride, access the up and down valve control and display it in a separate message text. You should consider which messages should be displayed at the same time and which should be displayed separately. Unfortunately, there is no general solution for keeping things in order. Divide your program into different areas and describe them in the program. Sort the building blocks logically and label them. Overlaps are to be avoided in any case. UDF building blocks could be of help with repetitions. I have attached what it might look like. Or look in the German part of the forum. |
