5/22/2008 7:25 PM | |
Posts: 2661 Rating: (279) |
env: Most likely your problem is connected with the PLCSIM. Check the link below: Which version of S7-PLCSIM can you use with CEMAT V7.0? |
6/3/2008 11:06 AM | |
Posts: 7 Rating: (0) |
tks all. The solution is: changes from AS-ACK mode to GR-ACK mode (System CFC) then it's work. |
