11/19/2019 8:17 PM | |
Posts: 17 Rating:
hi I need to change a 6GK7 443-1EX11-0XE0 by a new one 6GK7443-1EX30-0XE0, Do I need to change the HW or the module is plug and play? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 11/20/2019 09:58:19New subject after splitting |
11/28/2019 3:51 AM | |
Joined: 9/27/2006 Last visit: 9/10/2024 Posts: 12282 Rating:
Hello CP341; Siemens has developped a Compatibility Tool that will tell you if the different modules (in their different versions) can be used together. https://support.industry.siemens.com/cs/us/en/view/64847781 Nothing in a PLC configuration is actually plug and play; I have explained the general rules that apply to replacing a module by its successor (without modifying the hardware configuration). Outside of that specific situation all elements must be adequately parameterized, if they are compatible. Hope this helps, Daniel Chartier |
