5/16/2023 8:04 AM | |
Joined: 8/3/2009 Last visit: 9/11/2024 Posts: 13647 Rating:
Hello AutoGen_3137851 first of all we need a few more information: - Which SIMATIC Net Version do you use? - Which PLC do you access with your SIMATIC NEt OPC Server? - Which TIA Portal or Simatic Manager Version do you use in this case? A lot of general information you will find in this basic example: https://support.industry.siemens.com/cs/ww/en/view/67295801 Bye Murof |
