10/31/2011 9:24 AM | |
Joined: 1/26/2011 Last visit: 8/11/2022 Posts: 243 Rating:
Hi aterris, AttachmentExample.zip (655 Downloads) |
11/1/2011 7:19 AM | |
Posts: 8 Rating:
Hi Bigfoot, Ok please find attached some pictures of my configuration and explanation of my problem. 1) The PC Hardware Configuration pic shows the configuration in the hardware configurator in Step 7. 2)IE General IP Address shows the IP address of the IE general in Step hardware configurator (This is where i am able to change the ip address to something new download to the microbox and step 7 configuartion chnages online) 3) Microbox Station Configurator shows the station configuration in the microbox this is where my problem is the IE General IP address never changes here and is always greyed out not allowing me to change it on the microbox also in the network configuration for windows i am unable to change it their it says i need to install and enable a network card which already is. Hope this is more clear for you now. Regards Alan AttachmentIp Address.zip (519 Downloads) |
11/2/2011 11:26 AM | |
Posts: 8 Rating:
Bigfoot, Ok this is my problem in teh windows network configuration it will not let me change the ip address.See attached more pics. Attachmentpics.zip (554 Downloads) |
11/2/2011 1:04 PM | |
Hi aterris, okay now i understand your problem. :) sorry i was on the wrong way Well some questions: Have you tried to Shutdown the Controller and try then to change the IP address? Have it ever worked to change the IP before? Have you tried to Reinstall the Driver for the network card? (Deinstall and then Install) http://support.microsoft.com/kb/308939/en-us Maybe this would help you. I hope so! greetings bigfoot |
