4/15/2024 8:56 PM | |
Joined: 7/7/2010 Last visit: 5/15/2024 Posts: 14734 Rating: (2368) |
Converting the text (excluding the 00's at the end): SY100.IE4010.2 If that is the name of the Cisco switch device or port, you have obtained the correct information. UINT64 means you need 4 16-bit registers for a value the Siemens PLC cannot directly address (without some special library you would need to find or build). (FYI I used this link to convert the hex to ASCII: https://www.rapidtables.com/convert/number/hex-to-ascii.html so that I could guess how close you were already)
science guy |
4/16/2024 7:12 PM | |
Joined: 3/9/2023 Last visit: 5/15/2024 Posts: 18 Rating: (0) |
I managed to get the data reading in on array of Wchar, now how to i convert that Wchar array to a string ? |
