7/29/2016 10:54 AM | |
Posts: 111 Rating:
Hello redoksas, perhaps this manual might help you: chapter 6.11.4 "Display of faceplate for redundant components" |
8/1/2016 1:36 PM | |
Posts: 111 Rating:
Hello again, because your needs with the icon, at the moment I don't know what you exactly want: perhaps you have to create your individual faceplate for the PC objects icons. Sorry, if I can't help you. Because the initial issue with the update of the MaintenanceState bits, I found some hints in the documentation: SIMATIC Process Control System PCS 7 Maintenance Station (for your SIMATIC version V8.0, you have to select the edition "11/2011". In the documentation there are some chapter which might help you: 3.1 Differences between the versions 4.12.5 How to update the user diagnostic structure 5.10.3.5 "Diagnostics" view PC objects area
