3/27/2014 12:56 PM | |
Joined: 2/6/2009 Last visit: 6/18/2024 Posts: 939 Rating:
Hi All, There is a problem with the client PC that does not open any picture exept the alalrm window. At the server PCs everything works fine. Even when I tried to open picture by option "open picture by name" if gives error 'Picture object not found'. I have tried deleting the entire client and recreating it again, same problem appears. Please help me to find out the solutio
AttachmentScreenshots.zip (45 Downloads) |
Last edited by: Saravana kumar at: 3/28/2014 4:09 AMScreenshots added. _______________________________________________________________ |
5/20/2014 7:01 PM | |
Joined: 8/19/2012 Last visit: 7/7/2024 Posts: 125 Rating:
hi you can see THAT 1-SEE the Full computer name 2-workgroup compare it by other PC |
5/21/2014 11:00 AM | |
Joined: 4/8/2013 Last visit: 6/30/2024 Posts: 95 Rating:
as said before you can try to manually generate server data of your server after completely recompiling it, doublecheck \ reassign the package assignment of the Client WINCC station and then try it again after downloading the Client. in /tf/WW/en/Posts/25461the steps are also stated by cBo |
