5/1/2020 11:01 PM | |
Joined: 9/27/2006 Last visit: 7/8/2024 Posts: 12268 Rating:
Hello ZHK; I have no knowledge about your PLC , unfortunately. Here us the WinCC v7.5 SP1 system manual, with information on communication channels supported by the SCADA system. https://support.industry.siemens.com/cs/bh/en/view/109773067 See the accompanying screenshot. If you find no protocol directly supported by your PLC, is there a possibility of an OPC server, this is often a possible solution to bridge a missing driver. Hope this helps, Daniel Chartier |
8/26/2020 2:04 PM | |
Joined: 2/18/2013 Last visit: 7/10/2024 Posts: 139 Rating:
Hi Kevin, Russian Siemens SBT support claims that it is possible to connect directly (using Modbus TCP/IP protocol). Going to test it in several weeks!
