10/8/2020 10:28 AM | |
Joined: 11/14/2018 Last visit: 10/31/2023 Posts: 502 Rating:
Hello Ebubekir97, i think you first have to convert the interger variable into a string or char variable. For the conversion have a look at these posts: I hope this helps! Regards, Nzett11 |
If I could help you, be so kind and rate my contribution. :) |
10/8/2020 10:43 AM | |
Joined: 8/27/2020 Last visit: 12/11/2022 Posts: 16 Rating:
How do I include Converting an integer variable into an ASCII variable in WinCC program that you mentioned here? |
10/8/2020 10:53 AM | |
Joined: 9/23/2005 Last visit: 7/12/2024 Posts: 4615 Rating:
http://www.cplusplus.com/reference/cstdlib/itoa/?kw=itoa |
Regards, |
10/8/2020 11:21 AM | |
ı dont understand you |
10/8/2020 12:12 PM | |
Hello Ebubekir97, as mentioned in the post I linked, you can use the sprintf-c-function. In short: Some side information: If you use VBS instead of C, you can use the function "CStr()" for converting to string. Regards, Nzett11 |
10/8/2020 3:51 PM | |
I understand what you said, but I don't want to do it. I want to make the newly formed word True after I combine it. |
