5/17/2023 10:21 AM | |
Joined: 3/30/2020 Last visit: 7/12/2024 Posts: 4624 Rating: (967) |
I still do not have direct answers but maybe some research hints may help. Using the search words "routing S7-1500" delivers some interesting results. Best to try them yourself and see what makes sense -- if no further response is received here. Possible helpful candidates.. On the forum pages is S7-1500 Routing (PC -> CPU -> HMI connection). One of the important suggestions from Mr ChristophD was: "try to change the panel setting [from] Ethernet to Profinet". Then the knowledgebase article: Which S7-1500 modules support the "Routing over S7 connections" function? A link is given to documentation (59192925) that handles routing in detail. |
Activities of this user is voluntary. There is no obligation or liability placed on this user. Though optional, your 'please' and 'thank you' is highly valued. |
5/19/2023 8:10 AM | |
Joined: 4/12/2023 Last visit: 7/10/2024 Posts: 16 Rating: (0) |
Hello again, This is my first question on this forum, and because of that, I couldn't explain my situation clearly. I have tried to prepare another Word file to explain my problem. Could you please take a look at it one more time? PLC : 1517f-3 pn/dp And also there is switch between PLC and PC. Its IP adress is : 142.12.101.3 I apologize for the misunderstanding. AttachmentProblem.docx (312 Downloads) |
Last edited by: AutoGen_113656 at: 05/19/2023 08:55:07Last edited by: AutoGen_113656 at: 05/19/2023 12:02:32 |
