3/18/2016 1:17 PM | |
Posts: 648 Rating:
Hello tometrajkov, at the Siemens Online Support Homepage you can find a application for WinCC V7.3. https://support.industry.siemens.com/cs/document/101908495/wincc-connection-to-s7-1500-s71200-and-et-200sp?dti=0&lc=en-DE Since V7.2V you can use a communication channel "SIMATIC S7-1200, S7-1500 Channel". With best Regards rh1990 |
5/6/2016 2:34 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4770 Rating:
New question published by Project Engineer Process Automation @ Pfizer Puurs is split to a separate thread with the subject Connection between a S7-1500 PLC and Wincc V7.0.3. Best regards |
