9/4/2024 9:26 AM | |
Joined: 2/4/2021 Last visit: 9/4/2024 Posts: 2 Rating: (0) |
UPDATE Already has been solved changing the time of HMI according following link: https://support.industry.siemens.com/cs/ww/en/view/109820712 Regards! |
9/5/2024 7:59 AM | |
Joined: 8/3/2009 Last visit: 9/6/2024 Posts: 13594 Rating: (1720) |
Hello oep88 Yes, systemtime is a matter in the newer FW Versions because of the communication certificate. If you still have troubel with simulating only HMI and communicate to real PLC then check if you have set the PGPC Interface correctly: https://support.industry.siemens.com/cs/de/de/view/109748099 Bye Murof |
