10/21/2010 5:30 PM | |
Joined: 9/27/2006 Last visit: 7/14/2024 Posts: 12268 Rating: (2675) |
Hello Eduardo; I do not kow of any tutorial specifically aimed at ABB controllers as DP master, with a S7-300 as DP slave. But the subject has been talked about here before. There was a recent discussion on the forum recently where member fritz gave many suggestions to make a S7-300 work as a slave to a ABB 800xA DCS. You will find it useful: /tf/WW/en/Posts/33200 Also, the following FAQ shows step-by-step configuration of a S7 CPUas a slave to a S5 system; the Profibus configuration software for the S5 system isvery different from the S7 and could be considered as an equivalent (in your eyes) to the ABB Profibus configurator. It should help you setup your S7 slave for your ABB master: How do you operate an S7-300/400 as a DP slave on the PROFIBUS DP when the DP master is an S5 (with IM 308-C)? |
10/21/2010 8:40 PM | |
Posts: 4 Rating: (0) |
Thanks a lot dchartier. I will try this steps to solve this problem. Thanks one more time. |
