4/19/2013 1:02 AM | |
Posts: 1 Rating: (0) |
I'm not sure if it helps... I have WinCC Flexible 2008 SP3 Upd3 installed on Windows 7 64bit. I also installed the optional OPC-XML Gateway which comes with it. In relation with determining the correct URL to be used in your Kassl client, maybe the attached screenshots can be of some help... try having a look. The second screenshot (URL) shows the contents of the file RT2XML.dcf you find in the hidden folder C:\ProgramData\Siemens\OpcXmlGateway In relation to testing the OPC server your can do it directly in WinCC as indicated in pdf document at https://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&lang=en&objid=22701694&caller=view At page 25 I see there's a Test Server button... As mentioned in post https://www.automation.siemens.com/tf/WW/en/Posts/7365 Please, let me know how, if you (already) solved your issue with the Kassl client. Thanks. |
